Reports: Set minimum map scale map showing multiple features?
574
05-13-2025 10:41 AM
AlfredBaldenweck
MVP Frequent Contributor
I'm working on a making a report template right now and I'd like to have a map question showing all the geopoints in that repeat.
So far so good.
However, I'd like to set a minimum scale, so that no matter what, each map is at least 1:1000, for example. As it stands right now, a geopoint question matches the scale set or the extent of all features in the map.
How can I set a minimum scale for this?
Neal_t_k
MVP Regular Contributor
AlfredBaldenweck
Thanks for the response.
I've been experimenting with that, but if you set a scale that would be too zoomed in to see all of the features, it will zoom in past them. So, if you set the scale to like, 1:1000 and then you have points 30 miles apart...
What I've settled on is two maps: one that appears if there's more than one geo point and one that appears for one geopoint. I set a scale for the single geopoint map but not for the multiples.
I don't love this.
Honestly, I don't love any of the way the reports handle maps. For one thing, at a minimum let me print the scale the maps is set to. Impossible unless you manually set it, it seems.
Neal_t_k
Could you set the map scale based on a condition i.e. repeat count?  Have one condition for 1 and another for multiple.
AlfredBaldenweck
The way I ended up going about this was by adding four fields to the parent record that buffered based on the extent. basically adding an additional 1/4 of the distance between Min X and Max X, and Min/Max Y.
For cases where there was only one record, I just buffered by a constant.
