Reports for Fields that are not created on the feature layer.
405
08-16-2024 06:43 AM
Chet13
I was wondering if there are issues when creating a report using a field in Survey 123 that has the bind::esri:fieldType set to 'null'.
Does the report still capture the value even though the field is not created on the feature layer?
jcarlson
MVP Esteemed Contributor
It will not, no. The report has access to all fields in the layer, but as the report service is separate from the survey itself, there's no way for it to know about those null fields.
What's the use case here? If it's worth including in the report, it's probably worth tracking as an attribute, isn't it?
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
Chet13
The first version used integer driven fields through the report, new client had wanted choice driven fields in the survey to limit user error and visibility of distinct numbered answers. I was trying to determine which one to keep rather than have both a string and integer field for each question in the feature layer.
