Report Template: positions of nested repeats
283
6
10-28-2025 01:01 PM
danbecker
I have a nested repeat of noncompliance and noncompliance_photos.
${#noncompliance}
$#{noncompliance_photos}
In a feature report template, how do I use the $feature keywork to get the position of each record?
${#noncompliance}${if (noncompliance_photos | getValue:"count")>0}
Non-compliance Number: ${$feature | getValue: "position"}
Photo Number: ${$feature | getValue: "position"}
The above only gets the position of the inner-most repeat, not the parent repeat.
Any help with this?
Neal_t_k
Did you try like this?  The non compliance number is is in the parent repeat, and in the above you are calling in the child/photo repeat.
${#noncompliance}
danbecker
I have this at the top, so that the entire section can be skipped if no photos exist.
But I guess, that starts the noncompliance_photos parser?
Neal_t_k
In that case, not sure if this will work or not:
${#noncompliance}
danbecker
unfortunately, that doesn't work. It then thinks both #noncompliance and #noncompliance_photos are unclosed.
Neal_t_k
Could you put a counter in your parent repeat to count the number of photos in the child repeat. Then something like this:
${#noncompliance}${if countphoto>0}
danbecker
I ended up putting a counter on the parent repeat.
