Report Temaple experession to return select_one name instead of label?
2547
07-12-2018 04:15 PM
VirajP
I want to pull the name value from my select_one list into the Report Template instead of the label:
The label looks great in the Survey123 app:
But I need the actual DB value (i.e. '9') in the Report Template instead of the verbose label ('<b>9</b> - Very Good, New Condition')
Alternatively is there an expression that will pull a specific character into the Word Doc report instead of the full label?
ZhifangWang
Hi Adam,
Yes, you can use ${fieldname1 | getValue:""} to get the raw value of an underlying field. For a string field with coded value domain, it will return the code, for a date field, it will return the Unix time.
For example, ${expertise} returns "None. I have never used it." (the name of the coded value domain) while ${expertise | getValue:""} returns "none" (the code of the coded value domain).
by Anonymous User
Not applicable
Zhifang Wang‌ Can you please look into this and update user if it is currently possible? Otherwise can we create as possible enhancement request to use a parameter?
ZhifangWang
Hi Adam,
VirajP
Worked like a charm, thanks.  Where is the best place to find a listing of these functions?
by Anonymous User
Not applicable
Hi Adam,
You can find the supported expressions in the Survey123 Online Documentation: Print survey results—Survey123 for ArcGIS | ArcGIS
Phil.
