repeats section is not populate with the data
1588
02-24-2022 01:49 AM
GregoireCatineau
My repeats section is not populate with data, but the form posting works from Survey123 Connect.
( I want to use the repeat section in update mode.)
Should I put allowUpdates=true in the same line where is "begin repeat" in the field bind:esri:parameters ?
Is there a parcitular parameter in the Settings sheet to set or somewhere else ?
Regards.
by Anonymous User
Not applicable
Hi @GregoireCatineau,
You also need to include the query parameter, as per the documentation. Try:
query allowUpdates=true
in the bind::esri:parameters column.
Regards,
Phil.
PanGIS
here a blog about repeats, Section:  "Repeats in the Inbox"
Survey123 Tricks of the Trade: Repeats - Esri Community
by Anonymous User
Not applicable
Regards,
Phil.
GregoireCatineau
It's work now, thank you Philip and PanGIS
