Removing a complete entry from Survey123
499
10-26-2022 07:49 AM
JackBien
I have hundreds of entries in my Inbox for my survey is it possible that when a certain field is submitted as "Complete" that it could remove it from the Inbox but keep it in the data so it can still be accessed.
Katie_Clark
I've actually never done this with any of my surveys, but it sounds like you could use a WHERE expressions for this?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm#ESRI_SECTION1_635E8...
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
