Can someone recommend or provide their experience using an external GPS receiver with S123 on a Surface Pro 7+ device?
The accuracy of the GPS is not critical. Something within a meter or so would be plenty accurate. The purpose is to record a reasonably accurate location of assets in the field whilst offline.
I know ESRI has a page that defines some GPS high-accuracy receivers but I'm interested in experience of others and, as I said, high accuracy is not a requirement in our case.
https://doc.arcgis.com/en/survey123/desktop/get-answers/high-accuracy-use.htm
Also curious of approximate costs of receiver if you know.
Thanks, BKS
Bad Elf makes a few different options depending on your needs and budget. They're very simple and reliable to work with.
