Recommendation for external GPS for Surface Pro 7+ with S123
1230
02-28-2022 01:02 PM
BKS
Can someone recommend or provide their experience using an external GPS receiver with S123 on a Surface Pro 7+ device?
The accuracy of the GPS is not critical.  Something within a meter or so would be plenty accurate.  The purpose is to record a reasonably accurate location of assets in the field whilst offline.
I know ESRI has a page that defines some GPS high-accuracy receivers but I'm interested in experience of others and, as I said, high accuracy is not a requirement in our case.
https://doc.arcgis.com/en/survey123/desktop/get-answers/high-accuracy-use.htm
Also curious of approximate costs of receiver if you know.
Thanks, BKS
jcarlson
Bad Elf makes a few different options depending on your needs and budget. They're very simple and reliable to work with.
- Josh Carlson
Kendall County GIS
