Quote marks
1857
11-05-2019 10:11 AM
PetronilaMandeno
I knew I shouldn't have included the quote mark in my answers, but I did. And now I'm regretting it. Here's my conundrum:
In a Survey123 survey, I can about hose connection size. The options for the question are:
1 1/2" (for one and a half inches)
2 1/2"
4 1/2"
The choice of answers recorded are:
1_1_2"
2_1_2"
4_1_4"
They all have that trailing quote. To be honest, if I had noticed it before publishing, I would have deleted the quote mark, but I didn't.
Anyway, now when I try to export a feature report, the answer for that question doesn't export.
At the moment, the way I have it in my Word document is like this:
Hose connection size?
${hose_connection_size | selected:"1_1_2"} 1 1/2"
${hose_connection_size | selected:"2_1_2"} 2 1/2"
${hose_connection_size | selected:"4_1_2"} 4 1/2"
${hose_connection_size_other}
This doesn't return anything (obviously, because of the extra quote). But when I add a quote mark at the end like this:
${hose_connection_size | selected: "1_1_2""} 1 1/2"
I get this when I upload the word template:
Error: Failed to parse ${hose_connection_size | selected:"1_1_2"”}.
So, that's not working. Does anyone know how to get around this?
Thanks in advance...
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Petronila,
You should be able to 'escape' the quotation mark by using a \" in place of " :
${hose_connection_size | selected:"1_1_2\""} 1 1/2"
PetronilaMandeno
As a work around, I already changed the template so that the report returned just the answer. That worked, but I couldn't have the little check box format.
Next time we change the template, I'll try using the forward slash. Thanks for the tip!
by Anonymous User
Not applicable
Hi I have lat/longs written in DMS but without the special characters ie.  "40 18 12.12345 N"
I want to have a survey123 question that's hidden that will add in the special characters so it looks like this, "40° 18' 12.12345" N"
I was planning on using the concat function combined with the substr function to pull certain parts then add in the characters.  I ran into a problem trying to add the single quote (').  I couldn't get it recognize the single quote.
This is what I had below.
concat((subtra(${DMSLat},0,2})), '°',(subtra(${DMSLat},3,5)), ''',(subtra(${DMSLat},6,12)),'" N')
So ultimately my questions is: A. How to do I add a single quote to an answer and B. Is my script correct?
Katie
