pulldata("@property", 'language') doesn't work for web app?
1876
09-08-2021 08:36 AM
Ming
Multiple language Survey123 form with Standard Template,  try to use pulldata("@property", 'language')  to get current language, for field app it works well,  but for web app it always return "en".
https://survey123.arcgis.com/share/93eb8ce973b645c58386b98370c7c010?portalUrl=https://msdidfo7.esris...
IsmaelChivite
Esri Notable Contributor
This is a known software defect currently logged as BUG-000137706 BUG-000137670 and scheduled for a fix with the 3.13 release on September 16. See the Fixes section at: https://community.esri.com/t5/arcgis-survey123-blog/what-s-coming-in-arcgis-survey123-september-2021...   Please note that for the fix to take effect, you will need to install Survey123 Connect 3.13 and republish your survey or disable version locking.
IsmaelChivite
KrisRobbins2
Could this be the same issue that is causing the geopoint pulldata calculation to fail with this error message?  "There has been a problem trying to replace ${location} with the XPath to the survey element named"
I'm getting this same error when I try using the geopoint pulldata calculation for Lat and Long auto population in my survey as found here:  https://community.esri.com/t5/arcgis-survey123-blog/pulling-data-from-geopoint-questions/ba-p/896838
Everything is set up exactly the same in my survey as it is in the example but I get this error every time that I try updating the survey from the XLSForm.  Any ideas on why this may be happening?  Thanks!
