Pulldata from offline maps
3661
6
12-13-2023 10:01 AM
TaylorGroves
I am using pulldata() to auto populate a question field based on a user's location in an online feature layer.
However, the user must be connected to wifi for the fields to calculate correctly. This is an issue for some of our field workers and creates the potential for data errors.
Since we've had the new update that allows survey123 to be linked to offline maps, is it possible to query the offline map and for pulldata to calculate offline? I am querying a single feature layer.
ZacharySutherby
Hello @TaylorGroves,
Unfortunately pulldata("@layer") is an online only function at this time and does not work offline. We have an internal issue to support this in the future, but is in our backlog.
Thank you,
Zach
MathieuBoonen
Hi @ZacharySutherby  Hope this reaches you well.
I would be interested if any progress has been made with this  functionality as I face the same issue whereby field staff are often not in Wi-Fi or cellular coverage . Please keep me updated with any progress.
Thank you,
Mathieu
TNGStewardship
Hi @ZacharySutherby
I would also like to request if this topic, using pulldata offline, has been addressed.  We are never connected to wifi or within cellular range when collecting data as we are collecting data in remote areas during fieldwork, and would benefit from pulling information from published layers of information.
RichardPasquale
I would like to know more and see an update allowing this function to pulldata from a layer in a connected offline/fieldmap.
laurentideicesheet
I would also love to see an update on this!
LocationTeam
Hola
Me gustaría saber si se ha avanzado sobre el tema del uso de pulldata sin conexión o alguna funcionalidad similar que permita obtener información de una capa.
Ya que me enfrento al problema que los relevadores a campo no tienen conexión y sería importante poder contar con esta funcionalidad.
Agradecería cualquier novedad al respecto.
Saludos.
