Public survey requires login in order to access a non existent item.
922
08-23-2023 11:32 AM
EduardoDiaz
Hello, I designed a survey with Survey123 Connect, version 3.18.123, everything regarding survey works as expected.
The issue appear when I open the form in the explorer (edge, mozilla, etc.) then I get the message in the image below.
I searched for the mentioned item and it is not included as a file from the survey files stored in portal.
All the necessary items of the survey have been setted as public.
JodyZhengLiu
Hi @EduardoDiaz ,
Did you reference this item in your survey questions? i.e. in a pulldata("@layer") calculation or dynamic list using the search() appearance?
EduardoDiaz
Thanks Jody.
I found that the mentionated 'id' is from the basemap that geopoint question use. The documentation specify the list of maps that can be used as basic license (public?) within the survey and the basemap that my survey was using is included in the standard license list, so I modified the basemap in the body::esri:style column of the geopoint question and that fixed the issue.
