Problem with select one image displays on web app
972
11-19-2021 01:08 PM
LaurenMacLeod
I'm using images for each choice on a select one question. I created the survey in Survey Connect, and in the field app the images display beside each choice as a small thumbnail, that you can click to enlarge (this is great!). When viewing in the web app, the images appear large and offset. I'm fine with the larger size, but it seems like the default left-margin is pushing each of the images out of its respective box. Is there any way to add HTML to adjust the margin of these images to prevent this? This survey is intended for public use, so will be viewed using the web app version.
I've attached an image for reference.
Thanks!
