Problem with Select_one and Choice_Filter
434
02-26-2019 02:54 PM
GregoryLiggett
If the choice filter is active, to limit the choices by state in this case (STATES_ID), the geologic unit names (GEO_FORM_ID) do not show up on the picklist. If the choice filter is deleted, the names do show.
I have read this is a known issue maybe, but has it been fixed? I am using version 3.2.196. Anything to do?
GregoryLiggett
Thank you for checking that out, Marisa. That is exactly what I was seeing,
that with the choice filter in place the dots showed that the filter was
working, but the choices were not visible. I have changed gears a bit by
removing that functionality and limiting the survey to a single state.
I guess I should mark this resolved for now, but eventually I would like
this to work.
Greg Liggett
Montana State Office Paleontologist
Bureau of Land Management
5001 Southgate Dr
Billings, MT 59101
406-896-5162
www.blm.gov/paleontology
MarisaClaggett
Occasional Contributor II
Hi Gregory,
To confirm, are you saying that when the line, State1=${STATES_ID}, is under the column choice_filter for the Geologic Unit question, the choices for Geologic Unit do not show in the dropdown?
I created a survey with your survey and was not able to replicate that behavior.  If you created a new survey from file with a copy of the excel, can you reproduce the issue again?  If you have any more information or screenshots let me know!
Best,
Marisa
GregoryLiggett
this to work.
Greg Liggett
5001 Southgate Dr
Billings, MT 59101
406-896-5162
