Power Automate Failed Checks
769
12-09-2024 09:17 AM
RHammers
Hi All,
I have a flow that has suddenly stopped triggering. Here are the run details:
The API 'arcgis' returned an invalid response for workflow operation 'When_a_survey_response_is_submitted' of type 'OpenApiConnectionWebhook'. Error details: 'The API operation 'AddData' requires the property 'body/feature/attributes/pfr' to be of type 'String' but is of type 'Integer'.'
It does still trigger when the survey is submitted in edit mode (pulldatamode = 'edit'), so it's just when new surveys are submitted that it's not triggering. Any help on how to troubleshoot this?
abureaux
MVP Frequent Contributor
That's you issue right there. You likely have an incorrect variable somewhere in your flow. Without seeing your flow, i couldn't say. Any chance you can include at least a screen cap of the error in Power Automate?
RHammers
I believe it's a bug. It's the same issue that from this post, but for the select one from file question type. I changed the question type to text and now the flow is working.
https://community.esri.com/t5/arcgis-survey123-questions/survey123-power-automate-trigger-issues/m-p...
