Portal Connection Error with Survey123
3708
6
02-13-2017 11:29 AM
williamsalling
We have just federated Server and Portal and add a DataStore.  We are running Server and Portal 10.4.0.  We when try to add Portal to Survey123, we get "Survey123 requires that Portal for ArcGIS 10.3.1 or later and is configured with a  hosted server and argis datastore. Error.  I see that several have had this issue in the past but cannot find an answer or out come posted.
Does anyone have tips or answers?  Still waiting for Tech line to call back, thought I would try here while I wait.
Thanks
JamesTedrick
Esri Esteemed Contributor
Hi William,
We've seen some instances where the data store was not reporting its availability correctly.  We will be modifying Survey123's behavior in the future to not require the Data Store at time of Portal configuration.
williamsalling
James, so in the mean time do we try and redo the data store, if that is possible?  is there another work around?
JamesTedrick
Hi William,
You would want to open a ticket with Esri technical support to debug this issue; as an example, look at the discussion that occurred in Survey123 Connect won't connect to our 10.4.1 portal (w/ SAML configured) · Issue #572 · Esri/Survey...
williamsalling
Thanks James, I have been in contact with tech support for 3 days now. Still working on the issue.
Bill Salling
Senior Technical Specialist
3100 S.Gessner Rd, Suite 400
Houston, TX 77063
Email bsalling@ensiteusa.com<mailto:bsalling@ensiteusa.com>
Office 713-456-7780
Mobile 713-865-0640
www.ensiteusa.com<http://www.ensiteusa.com/>
IsmaelChivite
Esri Notable Contributor
william salling‌  A fix to this is ready in Survey123 Connect for ArcGIS 2.0 which is available for early adopters at the Survey123 Beta Program. More details at Survey123 and ArcGIS Beta Program announcement.
The fix is working a far as our testing shows, but if you could validate and provide feedback we will highly appreciate it. The best place to submit feedback for the Beta software is this Early Adopters Forum.
williamsalling
I will try and get it to work this week.  thank you.
