Permissions to take/submit surveys
395
09-25-2023 11:48 AM
HyeranKimm
hello. I created a survey in survey123 with my university account.
So in order to take the survey by clicking on the link, the survey participant has to be registered at my university and have an ESRI account. But I want everyone to be able to use the survey without a login, and I found a way to change this in the settings.
But there are only 2 options here, do I need to ask my school's IT team to make sure everyone can take the survey? Are these the only 2 options because I created the survey using my school account? Does anyone know of another way?
On this site (https://doc.arcgis.com/de/survey123/browser/create-surveys/sharesurvey.htm#ESRI_SECTION1_B9D04A0D3DF...) there are 3 options, but I can only see and select 2 options.
abureaux
MVP Frequent Contributor
Yes, you are missing the Everyone (public) option. This would be set by your GIS Admin, and it isn't likely something they will enable for you given your situation. You could always try though. Maybe they have a dedicated account set to for public surveys already?
HyeranKimm
I'll have to check with my university's IT department. Thanks for the answer!
