ordenar Nombre de instancia
447
07-22-2019 09:52 AM
Carlos_AndresCamacho_Acuña
en survey connect al crear la encuesta en xlsfrom en la pestaña settings. Al configurar el instance_name. quiero saber si se puede configurar un orden a los datos. ya sea ordenarlos por fecha o por orden alfabético. para cuando los vea en el dispositivo móvil en la bandeja de entrada se vean de forma ordenada
by Anonymous User
Not applicable
Hi Carlos,
Based on Google Translate you are asking the following:
In survey connect when creating the survey in xlsfrom in the settings tab. When configuring the instance_name. I want to know if you can configure an order to the data. either sort by date or alphabetically. so when you see them on the mobile device in the inbox, they look neatly.
The Inbox can be sorted by the user based on either the date of the record or the title of the record retrieved via the Inbox when selecting Refresh. You will see two buttons in the Inbox to do this. Therefore depending on how you configure your instance name, the sort order will be based by date or alphabetically, either in ascending or descending order.
You can not apply further sorting to the actual instance name setting in Connect.
Regards,
Phil.
