Hello,
I have two question.
1. I accidentally deleted survey form from folder. And layer remained. Is there any chance to restore deleted survey form(not created by XLSform)?
2. I tried to create new survey form on existed layer. But have not found any solution. Could you all assist me?
Solved! Go to Solution.
Not to my knowledge. The only way to create a survey against an existing service is to use Survey123 Connect.
Here's an article specifically about using S123 Connect with existing services:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/survey123withexistingfeatureservices.htm
