Multiple unique values appearing in feature layer of survey
1406
10-08-2021 11:25 AM
Bryan_Wade
I created a damage assessment survey in Survey123. When I go to adjust how the image looks there are multiple unique values showing for one of the questions. The question only has 2 answers, submitted and reviewed.
I recently did an update to the survey and noticed the issue because new submissions are showing up a different color than the other submissions. This also caused issues with a dashboard that displays the information. As a quick problem fix, I went into the survey data on the survey123 website and updated all the surveys to the correct information.
Does anyone have an idea as to why this might be occurring? I am using the new webmap and also the new dashboard.
DougBrowning
MVP Esteemed Contributor
Go in and calculate the data so it all matches up.  You may need to fix the domains also.  Ops may be using the domains to make that list.
AlfredBaldenweck
MVP Frequent Contributor
Was it published earlier, and you changed the options to be capitalized or not capitalized when you republished it?
Bryan_Wade
The survey was published earlier and there have been a few updates to it over time. I thought that might be the reason. The issue I am having is that the feature layer isn't showing the other options when I am creating an indicator in my dashboard.
DougBrowning
