Multiple photos in survey123 arcgis
13170
9
02-03-2020 01:50 PM
vijaybadugu
I wan to upload unlimited photos (if needed) in survey123 form . is it possible ? i want to edit photo in sent items in survey123 app .
Kanin
by Esri Contributor
Hello Samuel,
As per the blog posts https://community.esri.com/groups/survey123/blog/2020/08/07/whats-new-in-survey123-august-2020?sr=se...‌ and https://community.esri.com/groups/survey123/blog/2020/08/07/survey123-tricks-of-the-trade-photos?sr=... by Ismael Chivite‌, you can now control the maximum number of photos attached to a survey, without the need for repeats, in the latest release of Survey123 - August 2020 / v3.10. You can either let your users add as many photos as needed or control the minimum and maximum numbers of photos prior to publishing as well.
Also, you can set the upper limit of pixels in Survey123 Connect as well.
Please see the link and the screenshot below for more info: Media—ArcGIS Survey123 | Documentation.
CC: vijay badugu
Regards,
Kanin
Kanin
by Esri Contributor
Hello vijay badugu‌,
You can use Survey123 Connect's Repeat functionality to allow the upload of unlimited photos in Survey123. Please see the file attached for a sample configuration of this use case and see more details at this helpful answer by Ismael Chivite‌ at the link.
With regards to your second point, about editing photos in sent items in Survey123, I believe this functionality is currently an ArcGIS Idea. Please feel free to give it an upvote or provide some details how this functionality could be useful in your workflows.
Best regards,
Kanin
vijaybadugu
Do we need to include relational extra table for this ?
Kanin
by Esri Contributor
Yes, you will need an additional related table for this workflow, where the user can upload an unlimited amount of photos, to work.
Alternatively, you can create a survey with another configuration as per the attached file.
Note: This will allow multiple attachments without the need for an additional related table.
Warning: The number of image attachments allowed need to be set by the number of questions in the survey.
vijaybadugu
Thanks
SamuelSchneider
Do you know the maximum number of photos that can be attached to any survey, without the need for repeats? Photo size with be restricted to 1920 pixels.Kanin Sangcharoenvanakul
Kanin
by Esri Contributor
Hello Samuel,
CC: vijay badugu
Regards,
Kanin
EuropaxEarth
Do you know if this is still available in the most recent version of Survey123 Connect? I am on the media's pane and all I see is a blank screen:
AshleyEpperson
Is there a way to perform the solution above WITHOUT using Survey123 Connect?
NSum
Hi Ashley,
I had the same question and finally figured it out. When you have the photo question selected, in the pane to the right edit the constraint. You can select a min, max, or a range of number of photos.
