Multiple Choice Response Presentation
1555
01-27-2022 02:11 PM
godofsix
I'm trying to present my multiple choice question in a similar manner as the Survey123  data analysis on the dashboard. I want to present the response as column below so that each response can be represented as well.
 Instead of the possible responses
Any hints
by Anonymous User
Not applicable
Hi @godofsix,
Are you wanting to display the multichoice question in the Dashboard similar to Survey123 analyze page, where each choice is split out into it's own column? I don't believe you can do this with a simple widget in Dashboard. You would need to post process the data to organize it in a way that can be easily represented. The survey123 website does special processing behind the scenes to display it this way, as the values are just text strings with commas.
Phil.
by Anonymous User
Not applicable
Hi @godofsix,
Phil.
godofsix
Thanks
