Location Inaccessible error while the location setting is on
3256
8
01-09-2023 09:15 AM
YukoYokozawa
Some of my users complained they get the Location Error popup all the time. They are using PC and I told them to turn on the location service but it was already on. I let them re-install Survey123 but didn't solve the issue. Is there a solution to this problem?
DonovanC
Hi Yuko,
We are a running into the same issue as well.  What version of Survey123 are you running? We updated to the latest version and this is when the problem started.
josevaldes1
Hi, i also have the problem when update to the last version.
cdevault_pickett
I am also experiencing this. Does your Location Inaccessible error keep popping up so you end up having to click Close several times? However, if I view Location Status in Survey123 it shows location information.
AlisonOBrien
@cdevault_pickett , @josevaldes1 , @DonovanC , @YukoYokozawa
Which version of Windows are you using?
DonovanC
We are running Windows 10 Enterprise. The reason I believe it was not working for us was there was a registry key and the value was set to deny for location. Once it was set to allow the location services worked for us on the Windows application of Survey123. This was only affecting the newer builds of Survey123
cdevault_pickett
Not sure how I managed to miss these notifications. Also Windows 10 Enterprise here as well.
DonovanC
Hi @AlisonOBrien ,
We are now seeing the issues using Windows 11 and newer builds of Survey123
cdevault_pickett
I have since switched to Windows 11 and current builds of Survey123 (also see a similar error in QuickCapture).
