Long values in drop downs are wider than the drop down box
478
04-03-2023 05:26 AM
RayKidd
Hi all, this is probably a simple problem but I'm struggling.
I'm creating a survey using xlsforms which includes some drop down menus ('select_one list_X'). My drop downs contain some long values however, such that when viewing the form the text is wider that the actual drop down menu and so cannot be read in full. Is there any solution to this? Can drop downs be set to be the width of their longest item? Can I enable horizontal scrolling within the drop down box?
Thanks a lot!
Edit: Just to add that I'm using setting appearance to autocomplete, in case that makes a difference to potential solutions
mh401
I have the same issue. Any help would be much appreciated!
