Link lat/long to the Survey 123
635
12-23-2024 03:18 PM
GD2
HI everybody,
I am trying to add location(lat/lon) point to the Survey 123 form. I created custom expressions using Attribute Expressions in pops of the feature layer. But I am having issue to link it to the Survey URL:-
https://survey123.arcgis.com/share/d4d756cdcb1e4398b177c015dbfa22f4?field:treeid={ID}&field:treespec...
Needs to be be filled in the following boxes for each tree.
Any suggestion is highly appreciated.
Thanks
ZacharySutherby
Hello @GD2,
You'll need to use the `center` URL parameter to set the geopoint location based on a certain XY coordinate. Please see the Integrate with other apps documentation for more information.
Thank you,
Zach
MobiusSnake
MVP Regular Contributor
I seem to remember having trouble getting something like this working a while back, if I remember correctly I  ended up doing the following:
  • Created a hidden latitude field, with a null data type
  • Created a hidden longitude field, with a null data type
  • Used field: arguments to pass lat and long to those fields
  • Had a calculation on the shape field to concatenate the two hidden/null fields
ZacharySutherby
Hello @GD2,
Thank you,
Zach
GD2
Hi @ZacharySutherby
Thank you very much for this suggestion. It worked. I have one more query. On Survey 123, how can I add a pin to the location? I mean I need the blue point on the map for location as below. Currently its blank.
