Creating month, day, and year for date of birth separately in Survey123 Connect Form
1182
12-23-2024 08:53 PM
Almaz_Naizghi
I am designing a survey in Survey123 Connect and part of the questions are to collect date of birth as a month, day, and year separately, see print screen below. How can I format these questions?
Thanks!
2 Solutions
ChristopherCounsell
MVP Frequent Contributor
I would recommend having a single date question instead of 3 separate questions.
If you must have three, it suggests you have data requirements, which would dictate how you should format the questions. With no clarity on this I would recommend:
  • Day: Integer question, constraint for >0 and < 32
  • Month:
    • Integer question, constraint for >0 and < 13
    • Or a select_one question with a month choice list for each month
  • year, integer question, constraint for >1900
You could also add a list to the year/day questions and try different appearances like autocomplete.
TomWingrave
Is the requirement to ask the question in this way (i.e. the three separate fields for Month/Day/Year) or is it to return/store the data in this way? If it is the former then Christopher's suggestion below should work great. If it is the latter then you could ask a single date time question and then have 3 hidden fields which pull the elements out into their respective fields using the format-date function.
Year; format-date(${Date_Field},'%Y')
Month; format-date(${Date_Field},'%m')
Day; format-date(${Date_Field},'%d')
Further guidance can be found under the Date formatting section on this web page; https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#:~:text=You%20can%20u...
ChristopherCounsell
  • Month:
Almaz_Naizghi
Thank you for your quick response and recommendation.
I will try to convince the team who are requesting the survey to get a single date entry instead of 3 separate questions.
TomWingrave
Almaz_Naizghi
Thank you for your prompt reply!
To answer your question the request was the former to get three separate fields for month/day/year.
As, Christopher's suggested it is better to get one date entry instead of three separate fields.
