Issue with read-only select_one question in IE11
805
11-08-2019 03:46 PM
LindsayKing1
We have a Survey123 form configured to calculate an age, and then based off the calculated age, indicate which paperwork form applies.  This "form_51505585" field is should be automatically completed based on the calculated age, and should be read only so that it cannot be changed.  Here is how it is currently configured.The form_51505585 field is configured to be read only and to calculate automatically based on the calculated age.
In testing, we discovered that the field behaves as expected in Chrome and Firefox.  However, in Internet Explorer 11, it is possible to click on the other answer, which un-selects the correct answer, at which point it is no longer possible to select either answer.  Internet Explorer 11 is the default browser on a lot of our customers' machines, so are there any suggestions for how we can make it impossible for the users to change the response to this question?  Thank you.
JamesTedrick
Esri Esteemed Contributor
Hi Lindsay,
Can I ask that you file a support ticket with Esri Support on this?  I can see the issue you are describing, though changing the calculation (in your case, the date) will reset the select_one.
