How to iterate through Survey123 responses for specific names, find missing names, and send missing names via email?
1375
11-07-2019 03:38 PM
NDFAdmin
I've been trying to figure out the best way using Integromat, to iterate through a series of survey submissions for a specific day (by noon each day), find names missing from the submissions, and then email those missing names to a supervisor. I've played with a number of options, including using filters but keep coming up short.
It would also be of interest to be able to iterate through a set of responses, find names that are missing and then notify those missing people via email.
Has anyone tried to do this or know of a method?
Thanks!
Aaron
JamesTedrick
Esri Esteemed Contributor
Hi Aaron,
This concerns less Survey123 than simply accessing the feature service (as is done in A simple e-mail notification system for Survey123 for ArcGIS v2 ); it may also be a bit more straightforward to do in python than a webhook framework.  I would query the feature service, asking for the count of features grouped by submitter name for the time period (see Query (Feature Service/Layer)—ArcGIS REST API: Services Directory | ArcGIS for Developers , particularly using the returnDistinctValues option with your submitter field as the only entry in outFields). The comparison is fairly straightforward in Python; in a webhook context, you would probably need to use an iterator object to do the check along with an Array.contains function.
DougBrowning
MVP Esteemed Contributor
This is exactly how we do our QA.  I have a Python script that hits the HFS directly.  Brings all the data down into a search cursor.  Then it does a bunch of checks and creates a csv file.
Code is something like this
endURL = "/query?f=json&where=1=1&outFields=*&returnGeometry=true"
#item_id_to_query = r'9cffbbee279f43b0af9a9ef65ddfe3237'
plotsURL = "/" + "0" + endURL
response = s.post(url+"/content/items/{}?f=json".format(item_id_to_query))
fs_endpoint = response.json().get('url')
# plots
q_response = s.get(fs_endpoint + plotsURL)
plotsF = arcpy.FeatureSet()
plotsF.load(q_response.url)
plotKeys = []
# get a list of Eval PlotKeys from Plots
whereClause = "EvalStatus = 'Eval'"
with arcpy.da.SearchCursor(plotsF,"PlotKey", whereClause) as cursor:
for row in cursor:
plotKeys.append(row[0])
NDFAdmin
Thanks! I will give the Python method a go.
