Is there a way to geotag a question to a layer in survey123?
687
01-04-2024 10:46 AM
Rama1356
Hello,
I'm creating a survey for peace officers. Is there any way for them to record an incident within a polygon (management zones), and that record is geotagged to a specific management zone?
The result would be: The officer records an incident within zone 3. They survey field for management zone will be automatically filled for zone 3.
I feel there should be a script for it, my I'm a beginner in Python. Anyone can help?
rwrenner_esri
Esri Alum
Populating an attribute value from an attribute in an overlapping polygon (e.g. management zone) can be done within the survey itself, no python needed! Provided you're already collecting a geopoint representing the incident location:
- If you're using the Survey123 web designer, you can use a spatial query calculation to pull in this value by specifying the source as Layer.
- If you're using Survey123 Connect, the calculation method pulldata("@layer") can be used which is described with examples here.
-Rylee
rwrenner_esri
Esri Alum
-Rylee
Rama1356
Thank you very much! It is working now. 🙂
