Is join(separator, question) supported yet?
4326
02-13-2019 12:58 PM
DougBrowning
MVP Esteemed Contributor
I found the join(separator, question) function listed on this help page
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
But when I use it I only get the value in the last repeat.  No comma or other repeat data at all.  It changes to the last value in the repeat whenever a repeat is added.
I saw some posts of it not being ready yet but that was back from Nov 2017.
Thanks
DougBrowning
My code is the same as yours.  But your sheet is doing the same thing for me.  occ_names will just display the value of the repeat I am on.  So if on repeat 1 it just lists repeat 1 value.  If I move to repeat 2 I get just repeat value 2.  It changes as I cycle back through the repeats also.
I have Connect 3.0.128.   ...And so I went and got 3.2.196 and now it works!
Thanks
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
The function join() is working properly for me in this sample- can you check to see what the difference might be?
DougBrowning
Thanks
TKSHEP
Hello,
Is there by chance a way to accomplish both of these command in a repeat?
For example I have a repeat to select_one that are names and I am trying to get the name to show separately.  I am trying to get the related table to show separately in Dashboard.  I hope this makes sense.
oice-name(choice, 'question')
Used for select_one and select_multiple questions. Returns the label associated with the name of the choice in the given question. Be aware the question must be defined inside quotes.
jr:choice-name(maybe, '${question_one}')
Concatenates all answers to a given question in a repeat, separated by the given separator.
join(',', ${question_in_repeat})
Thank you!
DougBrowning
Not sure combining like this would work but prob not
join(',',jr:choice-name(maybe, '${question_one}'))
So just add a second hidden field in the repeat that gets the label
question2 calculate of jr:choice-name(maybe, '${question_one}')
Then do your join on that hidden field.
join(',',${question2})
hope that helps.
