Integromat and Survey123 HTML POST error code 400
2679
04-08-2020 06:09 AM
NikHenry1
I have been following the configuration detailed here:
https://community.esri.com/groups/survey123/blog/2019/06/04/survey123-tricks-of-the-trade-integromat
Trying to update feature attributes using these parameters:
  • Key = f
  • Value =json
  • Key = features
  • Value = {"attributes" : { "ObjectId" :1. result: objectId, "globalid" :1. result: globalId, "justificationDetail" : "Very high growth rate for the species, restricting the ability to achieve clearance." }}
  • Key = token
  • Value= 1. Token
integromatHTML_paramaters_001
But I get this message:
  • Data : "error":{"code":400,"message":"Cannot perform operation. Invalid operation parameters.","details":["'features' parameter is invalid","Invalid object passed in, ':' or '}' expected. (90): {\"attributes\" : { \"ObjectId\" :1496, \"globalid\" :{78127F82-5DF1-4596-89B4-F607E7CCF14E}, \"justificationDetail\" : \"Very high growth rate for the species, restricting the ability to achieve clearance.\" }}"]}}
IntegromatHTTP_outputmessage_08042020
Any help would be appreciated. Cheers
JamesTedrick
Esri Esteemed Contributor
Hi Nik,
I would encourage you to use Apply Edits (Feature Service/Layer)—ArcGIS REST API: Services Directory | ArcGIS for Developers, which is a more robust editing resource.  Note that the in the UpdateFeatures resource, the features parameter is expecting an Array - even if you are only updating 1 feature, you need to provide an array [ ] object.
NikHenry1
Hi James,
Thanks for that feedback, but I still get the same type of error with ApplyEdits.
This was my configuration:
Integromat_Survey123_ApplyEdits_Config
This was the error:
{"error":{"code":400,"message":"Cannot perform operation. Invalid operation parameters.","details":["'updates' parameter is invalid","Invalid object passed in, ':' or '}' expected. (90): {\"attributes\" : { \"ObjectId\" :1499, \"globalid\" :{8AE51921-D053-440C-8533-949A2B778DA5}, \"managedCost\" : 116.36 }}"]}}
I'll keep investigating, thanks for your help.
Cheers
Nik
NikHenry1
Update: I started to think that maybe the hosted layer settings where causing issues.
So I checked the survey123 URL that Integromat was using and it was pointing to the '_fieldworker' layer, with these  settings:
survey123_fieldworker_hostedlayerSettings
So, I switched the URL to the base survey123 hosted layer. But, I still get the same errors with:
 - "Invalid object passed in, ':' or '}'
Any help or feedback would be great.
Cheers
Nik
dsletten
Hi Nik,
We're going through this same process and have followed the article on incorporating integromat as you did. Just curious if you were ever able to find a resolution to this error or came up with a different workaround?
Dan
