Image Browse function not working in survey
245
a week ago
dsinha
Hello, for a Image option in the survey, I have set the body::esri:style to method=camera,browse.
However, when using the browse option in the Survey123 app, the selected image does not get included in the survey.
Any idea what I might be doing wrong?
Thanks!
dsinha
Hi @Leena_Abdulqader, we are using Android tablets. I still went ahead and tried the solution suggested for iOS and it didn't work. I also tried converting the format to PNG (there is a post that mentioned that PNG works but JPG doesn't), but that didn't work either.
But your comment about the browser gave me an idea, and I tried to edit the submitted response from the Survey123 dashboard. I opened the Data tab from the dashboard, then selected the survey response, and choose the Edit function.
Then I used the Drop image here or select image function to browse to the image files and add them to the survey response. And this did work.
Leena_Abdulqader
Hi @dsinha, are you using an Android or an iPhone? Did you give the Survey123 app permission to access all photos based on this bug? https://support.esri.com/en-us/bug/the-arcgis-survey123-field-app-on-ios-devices-submits-b-bug-00015...
What kind of images are you attaching? Have you tried different formats and from different devices? Maybe also from the browser compared to the app?
dsinha
