I cannot click on a point in Fieldmaps after creating it in Survey123
3270
14
06-29-2023 03:24 AM
EdHixson
Hi all
I am experimenting with Survey123 and creating some points on a web map. When I load this web map into Fieldmap with the survey123 points created for some reason I cannot click on any of them, which is a vital part of the survey123 process. I have had a look through the setting and I cannot figure out why I wouldnt be able to click on the points to view their attributes
Anyone has any advice or help it would be greatly appreciated!
All the best
-Ed
EdHixson
Hi there
Thank you for all the information, on the back of this message I have decided to open a ticket with ESRI
Thank you
-Ed
MatthewStephenson2
Ed,
Did you work out a solution to this problem after escalating to tech support?  I am experiencing the same thing and for the life of me I cannot figure out why no pop up or form will appear in FieldMaps for features created using Survey123.
Matt
suntoygeo
I've never run into this bug before, but I have run into this problem as well, starting today.
Using a newly created feature service generated by survey 123 and attempting to also use its point layer in field maps. Pop-ups for the layer work in map viewer, but cannot get them to activate on the latest version of Android Field Maps.
Bummer to find this thread, heh. Would have been more convenient to realize it was some dumb mistake I was making, but this seems like a Survey123 thing.
suntoygeo
Okay - so I actually was able to fix this.. but I'm still pretty sure it qualifies as a bug.
Survey123 Connect does not include explicit settings for feature service capabilities - add, update, delete. Instead, it includes toggles like "Users can edit surveys in Inbox".
I was able to get pop-ups working in Field Maps by navigating to the feature service generated by my survey, and enabling "Update" in the editor settings.
I still think that's a bug. You should be able to view a pop up without being able to update a feature. And I wonder if my settings will be overwritten by Survey123, what would happen if I toggled back and forth.. etc.
But as a workaround, give that a try.
MatthewStephenson2
I eventually figured this out on my end as well.  This seems to the solution.  Would be nice if these settings could be configured in Connect at the time of publishing a survey.
