How to overcome Choice's limit if more than 5000?
315
01-08-2024 07:02 PM
VenkatDheeravath
Hello Dears,
My survey form is simple with few questions however my choices are many for demographics section (state to district to Township to Towns to wards to CUs) to cascade will be more than 6000 I think the limit in Survey 123 form is 4,000 only. Could anyone help me with some tips? I did try external choices, but it doesn't work.
I am attaching the form with partial filled choices which are now more than 4000:(
Thank you in advance.
Best -venkat
JenniferAcunto
Publish your choice options as a hosted feature layer or hosted table. Then use the search appearance to populate your choice list. This blog post provides a good overview of it, or you can check out the Dynamic Choice Lists Using Search Appearance sample survey to see it in action (including how to set up the cascading questions).
- Jen
