This is a bit odd.
The best way to explain it is: I want Survey123 to remove the calculation if another question is selected.
More in depth:
I have 1 geoshape, with multiple inputs, and it behaves differently depending on another question
I want to draw
I have one coordinate
I have multiple coordinates.
everything works perfectly. If I want to draw I can do so, if I want to add coordinates I can do that too and then it draw it for me, and the shape is created in the service.
The input from the coordinates are added to a concat to create a coordinate string, this is added to the calculation of the geoshape.
But as soon as that calculation are added to the geoshape the draft mode functionality wont work if I chosen to draw the area, then the geometry disappear. Any idea?
