How to make adding an additional photo required in Survey123 Inbox for image question?
905
04-05-2023 01:34 AM
ChristopherCounsell
MVP Frequent Contributor
Have a survey that is pulling existing records into the Inbox. There is an image question that pulls down images. The survey user can add more images to this question.
What I would like to do is make adding at least one more image compulsory. Setting a required status of yes on the question doesn't work as the conditions are met already.
I feel like there should be some way to achieve this using calculations, constraints and the count-selected() function but haven't appeared to get it to work successfully of yet. Maybe if I can't get it to work on the image question, I can put two null questions in with different calculation modes and have that act as the constraint?
Has anyone tried this before and got it to work?
DougBrowning
One idea is to have a second photo question that only shows when mode is edit then make that required.
Check out this post on how  https://community.esri.com/t5/arcgis-survey123-questions/editing-from-inbox-can-i-make-some-fields-r...
Hope that helps
DougBrowning
Hope that helps
ChristopherCounsell
Just having a second question did the trick. It'll always be edited through the inbox.
Couldn't find much information on working with images in the inbox - usually there's a great blog post by the Survey123 team on this but it eluded my grasp.
Thanks @DougBrowning
