How to link feature service layer in Survey123?
4402
7
05-07-2018 01:40 AM
AlfonsoDodero
Hello to all,
I'd like to update my existing feaure service via Survey123 but, when I create a new survey with Survey123 Connect starting from the feature service, only the first of the service layers is received by the system. I've tried to update the form_id and the instance_name but with no result.
Can you give me some suggestions?
IsmaelChivite
Esri Notable Contributor
Hi Alfonso. This is a known limitation of Survey123 Connect.  When using Create Survey->From Feature service, Connect always creates an XLSFile looking at the first layer of your feature service.  If you would like to create a survey that loads data in other layers, you will need to create the XLS file manually.
  • submission url: the URL of your feature layer item
  • form id: the name of the layer in your feature service you want to hit
  • survey worksheet: ensure that the questions in your survey worksheet reference field names that exist in the feature layer you are hitting
AlfonsoDodero
It worked perfectly, thanks.
NUVIAVILLAMIZAR
THANKS!
Ismael, you make my day!
ILoveMap
Hi Ismael,
Is this still the case that you need to manually create a XLS file that loads data in other layers of a feature service? Have there been improvements to this process?
Dudley_R_Hartel
I've seen this and other GeoNet threads on "submission url: the URL of your feature layer item"; but I have never seen the method for retrieving or creating the "layer Item " URL.
It looks like, for a hosted feature layer: https://usfs.maps.arcgis.com/home/item.html?id=0ee799a2234d4ff2942b7cd8b6d58e91
That the Survey123 (XLXs) "submission URL" is: https://www.arcgis.com/sharing/rest/content/items/0ee799a2234d4ff2942b7cd8b6d58e91
Is that the method and the correct "layer item"?
JamesTedrick
Esri Esteemed Contributor
Hi Dudley,
You are correct.  The link is the feature layer item's link in the ArcGIS REST API: Item—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers
Dudley_R_Hartel
Thank you
Your link to REST services helps
Dudley Hartel
Science Delivery/Technology Coordinator
Forest Service
USDA Forest Service
p: 706-410-5568
c: 706-410-5568
dudley.r.hartel@usda.gov<mailto:dudley.r.hartel@usda.gov>
747 Maxine Dr
Baton Rouge, LA 70808
www.fs.fed.us<http://www.fs.fed.us>
<http://usda.gov/>[Forest Service Twitter]<https://twitter.com/forestservice>[USDA Facebook]<https://www.facebook.com/pages/US-Forest-Service/1431984283714112>
Caring for the land and serving people
