How to hide dateTime on form but still save in feature layer?
1462
02-04-2020 01:11 PM
LS1
If I use type=dateTime and default=now() in my survey I get date/time showing up in feature layer like this:
I want to hide it on the survey but still save in feature layer to work with in Operations Dashboard.
If I change type = hidden and keep default=now(), the Date/Time shows:
I've tried putting fields in the these fields on the form but can't get anything to work. Help?
bind::esri:fieldTypebind::esri:fieldLength
Kanin
by Esri Contributor
Has your survey been published before? If so, please try creating a new field of another name and set the bind::type column accordingly. This is because if a survey has been published, the field type may be locked by the schema of the underlying feature service.
If this answer is helpful, please mark it as helpful. If this answer solved your question, please mark it as the answer to help others who have the same question.
Kanin
by Esri Contributor
Hello Lisa Smith‌,
As per Survey123 documentation:
Note that bind::esri:fieldType only controls the field type created in the feature service. To control the field type for a question during a survey, use the bind::type column.
Please try to set the bind::type column to "dateTime" in addition to the bind::esri:fieldType column. You could find a sample configuration in the attached file.
Best regards,
Kanin
LS1
I tried that but it doesn't work. This is the error I get when trying to set bind::type=dateTime "This value doesn't match the data validation restrictions defined for this cell"
Kanin
by Esri Contributor
LS1
Thank you. That worked.
