How to get multiple entries from a csv file?
916
02-22-2024 04:44 PM
PavlovaVitale
Hello I am hoping someone can help me with this issue. I have a survey that has multiple entries in a CSV file for example:
Watershed                     Pollutant
Los Angeles River          copper
Los Angeles River           lead
Los Angeles River            zinc
Machado Lake                 mercury
Machado Lake                  DDT
If I select the watershed to be Los Angeles River in my survey, how do I have it populate all the pollutants in the survey? pulldata only grabs the first record. I have at least 100 watersheds and multiple pollutants per watershed so I am not sure if an array would help at all.
ZacharySutherby
Hello @PavlovaVitale
Are you looking to populate a text question with the pollutants or a multiple choice question?
If you're looking to populate a text question you'll need to squash your data so that there's only 1 watershed in the CSV and then the pollutants can be a comma separated string like "Copper, Lead, Zinc".
If you're looking to populate a multiple choice question you can keep your CSV the way it currently is and use the search() appearance.
Thank you,
Zach
PavlovaVitale
We can't put the pollutants in one line nor the watersheds in one line because associated with each pollutant are the limits like copper has a limit of .003 and sometimes it is .02 and so they vary. I will try to figure out how to use search()
abureaux
MVP Frequent Contributor
An Idea:
  1. Determine the maximum number of pollutants and label the input fields 1, 2, 3, ..., x.
  2. In the CSV, have one watershed with multiple columns per pollutant.
  3. Use pulldata in the survey to pull from each of the "pollutant" columns and dynamically hide the input fields with no pollutants.
