How to add a space between joining string inputs
1026
06-30-2023 01:39 PM
AndrewCastilloTBSL
In Survey123 web designer, I have an input field that is calculated to join someone's name and their ID when I test it doesn't create a space between the name and the ID it's like "John1111" instead of "John 1111."
how do I include a space between strings when joining them in survey123?
fklotz
You can just enter a space into the gui between two joins operations:
It is not very clear but there is a single space between the two "joins" boxes.
I originally typed:
and the web designer changed it to the first image above.
Farley
