How long does a user remain logged in?
817
02-01-2018 11:20 AM
TL2
How long does the token last when logged into Survey123? (version 2.5)
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
The default length of time for a token from Survey123 is 120 minutes.  Survey123 also uses the refresh token capability to renew the token before it expires.  There will be situations where the app has been off for a sufficiently long amount of time that the refresh.
JoëlleMassy
Dear James,
So, how can we stay logged longer, at least one month?
Best
JamesTedrick
Hi Joëlle,
With the field application, the login system should allow a user to remain logged in for a month (closer to 3).  Are you experiencing issues remaining logged in?
