How i make an request sending an file end wating for response?
1144
07-16-2024 12:47 PM
Alex_matias
Im trying to make an http request , using the example :
function decodeVIN (VIN){
  // Output value. Initially set to an empty string (XLSForm null)
  let outValue = "";
  // Check the length to make sure a full VIN is provided
  if (VIN.length<11){
    return outValue;
  // Add the VIN to the decode VIN API request
  let url = `https://vpic.nhtsa.dot.gov/api/vehicles/decodevinvalues/${VIN}?format=json`;
  // Create the request object
  let xhr = new XMLHttpRequest();
  // Make the request. Note the 3rd parameter, which makes this a synchronous request
  xhr.open("GET", url, false);
  xhr.send();
  if (xhr.status !== 200) {
    } else {
    outValue = xhr.responseText;
return outValue;
But my i want to make an request that send an binary file in pdf end wait for a response.  Anyone know how to do that?
ZacharySutherby
Hello @Alex_matias
Custom JavaScript functions in Survey123 don't support asynchronous calls nor does it support accessing local files.
Thank you,
Zach
jelisjack
To send a file and wait for a response, you can use a tool or script that supports asynchronous operations. For example, in Python, you could use the library to send the file and then wait for the response business. Ensure that your server or service handling the request is set up to handle file uploads and provide a response.
