How do I create a survery using the child records of a nested repeat
507
02-12-2024 08:22 AM
NevilleCTT
I have greated a survey with nested repeats using the structure below
Building
  Dwelling
    Household
      household members
Can I use the inbox to show each dwelling for a building. so that for example if I have a building with five(5) dwellings (apt 1, apt2,...apt5) then I get five(5) surveys (apt 1, apt2,...apt5)? I don't want to scroll through the repeat to get to individual dwellings.
Regards
Neville
abureaux
MVP Frequent Contributor
Short answer is "no".
You may be able to launch from an external application to achieve that. But I don't see it being pretty.
An easier solution may just be redo the survey to focus on "dwelling" if that is what you care about.
NevilleCTT
Could you outline the external application method?
Since I don't know how many dwellings are in the various  buildings I cannot only focus on the dwelling. This Survey is for a Population and Housing Census.
