Greetings, I am using version 3.9 of Connect to create a survey. I would like to collect the name of the GPS receiver that is being used when data is submitted with the form. I have included a text type field with the name positionsourceinfo and a calculation of: pulldata("@geopoint",${location},"positionSourceInfo.deviceName"). Is this correct? I am able to collect the receiver name for a bad elf and trimble R1 but the field is left blank when the integrated GPS is used.
On a related note, I would like to include in the esri warning message a notification that the user is using the integrated GPS and not the BT GPS. How would I do that?
I attached the xls form.
b
Hi. The positionSourceInfo.deviceName property is only available for external GNSS receivers. This explains why an empty string is returned when you use the internal GPS. The built-in GPS does not really have a name that we can return. Alternatively, if you do not want to have am empty value, you could go with something like this:
if(pulldata("@geopoint",${location},"positionSourceType")='2',"Built-In GPS",pulldata("@geopoint",${location},"positionSourceInfo.deviceName"))
You can also use the positionSourceType property to figure out if the user is using an external receiver or not. For example:
| type | name | label | relevant |
| note | Please connect your external GPS | pulldata("@geopoint",${location},"positionSourceType")='2' | |
| geopoint | location | GPS location |
To learn about all the properties you can pull from a geopoint, check the Geopoints—Survey123 for ArcGIS | Documentation help topic.
Thanks!
Thanks!
Very helpful Ismael. Just what we needed. Thanks very much.
b
