How do I add a repeat to an existing survey?
1062
11-18-2020 08:12 PM
MikeOnzay
How do I add a repeat to a published survey without losing existing data?
Tags (1)
SMauri
Hi Mike,
just create your new survey with repeat in your ArcGIS Online/Portal. Then append your existing feature class in this new geometry.
Cheers
Stefano
SMauri
Hi Mike,
Cheers
Stefano
MikeOnzay
You are correct that a new service needs to be created. This knowledge base article describes a step by step solution. https://support.esri.com/en/Technical-Article/000023485
