I have a rather large set of data in related tables and I would like to create a survey to be used with workforce that can do the following:
pull data from existing entries if given an ID code (ideally entered in workforce).
Add new entries using input from surveys
While I know I can create surveys from existing feature services, most of the documentation I've found about previously existing data refers to overwriting entries, which is not what I want to do.
