Hi, very new to all this! Do users who are going to be asked to fill out a survey123 form out in the field, need to have a ArcGIS online account? *
355
05-08-2018 03:31 PM
IestynTaylor
I'm setting up a Survey 123 form that needs to be filled in out in the field by external contractors, Do these contractors need to have a ArcGIS online account to be able to access and use my survey?
JamesTedrick
Esri Esteemed Contributor
Hi Iestyn,
If you choose to keep your survey private (only the contractors have access), the users filling in the survey would need ArcGIS Online logins.  Survey123 also supports sharing forms out to everyone, which does not require a login.
IestynTaylor
So this means, if I share a form out to everyone. The person who needs to fill out the form can download the Survey123 app onto a device and then fill out the form without a login??
IsmaelChivite
Esri Notable Contributor
That is correct. If a survey is shared publicly, anyone can submit data to it (from a web browser, or from the Survey123 field app). More details about working with public surveys available in https://community.esri.com/groups/survey123/blog/2016/11/10/getting-started-with-public-surveys .
