Help with proximity editing
250
05-21-2024 01:49 PM
YenniferLinethCedeñoCampos
Hello
I am currently working on a form for a client who wants proximity editing to be activated, that is, I have a layer of Weather Stations, which are inspected every week, for each station there is an inspector assigned and he does not want to see the station he It is not his responsibility to inspect, to ensure that the information is actually loaded on the site, the layer of meteorological stations needs to be filtered in some way. In some extreme cases the same inspector can inspect other stations.
Is it possible to propose this scenario from Survey123?
abureaux
MVP Frequent Contributor
You can do this, assuming all your users have accounts, and the layer of weather stations has some sort of "user" field. You would compare the logged in username to that layer and filter out non-relevant items.
Have you read this? Dynamic Choice Lists using Search Appearance
