Group message indicating number of unanswered questions
660
02-17-2022 11:37 AM
RobertBorchert
Honored Contributor
I have developed a survey of buildings in our area.
I would like to start the survey out with the appearance of each group being  compact
What I would to know if there is something I can put in with the group header how many questions are not answered.
I have to many questions to make the any fields required as the users may need to Pull from the Inbox at times.
RobertBorchert
Honored Contributor
I found a solution that is not what I was looking for but it works just as well.
I inserted a note above the begin group row with a label of "Number of unanswered question in <group name>
In the calculations field I used and "if" statement
(if(${ACNORMALEMERGENCY} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECT} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTACCESS} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTTYPE} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTCONDIT} =‘‘,1,0)) + (if(${ACTRANSFERSWITCH} =‘‘,1,0))
Which resulted in  a Sum of the number of questions that are <null>
I then pasted the calculation into the relevant column so when the number of unanswered questions was zero it would turn the note off
(if(${ACNORMALEMERGENCY} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECT} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTACCESS} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTTYPE} =‘‘,1,0)) + (if(${ACSOURCEDISCONNECTCONDIT} =‘‘,1,0)) + (if(${ACTRANSFERSWITCH} =‘‘,1,0)) > 0
RobertBorchert
Honored Contributor
I am thinking maybe someway to display a value in the label from the calculated field
RobertBorchert
Honored Contributor
