Is it possible to pre-load points into 123, link them to a drop down menu that once selected will change the map view relative to that point?? Script?
Thanks!
Hi Scott,
Yes, it is possible to calculate the locations based on a dropdown. Geopoints receive a string that consists of <latitude>_<longitude>_<altitude>_<accuracy>, with the altitude and accuracy components optional. See Geopoints—Survey123 for ArcGIS | ArcGIS for more information, as well as the following samples available in Survey123 Connect:
Hi James,
From survey connect it works perfectly but when I publish and use it on my pc to enter data it doesn't work... Only work on the app.
I find this option very useful, is there any solution if you enter data from your pc?
Hi Pablo,
There is a version of Survey123 app available for Windows and Mac. Additionally, you could use the web form version that's created after publishing as well.
Hello @JamesTedrick ,
Is it possible to do the same with a geoshape question? To populate geoshape question map with locations from choice list?
I feel a little stuck here ... any guidance would be very much appreciated!
